I have a new to me 1989 Force 125hp. I have had it out once and all seemed well until the float bowl fell off. I have fixed that, now the darn thing will not run right.
I believe it to be an ignition problem.
Symptoms:
-Once in gear (under load if you will) the engine has great difficulty in increasing RPM and thus accelerating the boat.
-It does not reach max RPM, (no tach) but I would guess 2500-3000 RPM tops
-I assess that it has greater than normal vibrations
-I can remove the coil wire from 1,2, and 3 without stalling the engine. If i remove 4, the engine immediately dies.
I have:
-Complete cleaning of carbs
-new fuel lines
-completed the link and sync as per this forum direction. I pulled plugs and ground coils to set timing at 28 deg WOT at cranking speed. RPM were set by feel, slightly above stalling when shifted into gear.
-clear fuel filter prior to carbs. (always a decent amount of fuel available)
-fresh gas at 50:1
-new marine battery (non agm) (charged with charger prior to each testing)
-Compression test is 140-145 on all cylinders
SO, what next?
Should I set timing at 30 deg WOT on the water even if the engine is not running good?
Should I learn about DVA readings and follow instructions? who has the best instructions to follow?
What should I be looking at first?
It the long weekend and I want to go boating.....Thank you to all those that can help
Cheers
Rick
Symptoms:
I have:
-new fuel lines
-fresh gas at 50:1
SO, what next?
Cheers
Rick
