daboostcreep
- Jul 30, 2016
- 7
I was given a very very good condition 1994 Bayliner 1401LS with a Force 50 motor.
The motor starts up immediately and runs smooth.
The problem is the boat doesn't hole-shot very well and requires quite a bit of time to get on a plane, with just myself on the boat at 190lbs, and once on a plane it runs at about 22 mph indicated.
If I add another adult of about the same weight at 180lbs it becomes a slug and doesn't want to plane out, basically making the boat useless.
I know this much:
Compression is 120 psi per cylinder
Jets are clean and carburetor is otherwise clean.
Prop was replaced about 10 years ago with a 10 degree pitch Quicksilver unit.
Fuel is run at 50:1 mix and plugs are new.
I don't know this:
Factory prop pitch, or recommended pitch to get on a plane quickly.
RPM at WOT as I didn't have a tachometer with me.
Thoughts:
Maybe the timing isn't set aggressively enough?
Maybe the prop should be different pitch?
I appreciate your help in advance.
I know this much:
I don't know this:
Thoughts:
