hi
I have 1978 charger 115hp the hydraulic lift body module was leaking out the line person had it before cross threaded it... I was able to get one off a different engine from a boat wrecker place... it lifts and lowers the unit and no leaking from the lines....
but it cant hold itself up it starts to drop.... when in the up position what part is leaking on it inside? and cant I just pull something out and replace it?
the orginal one on front has a C clip and a plug... the one I got has a drain plug with an allen key on the front of it.. but is there an O ring I could just replace etc? so that it can hold the engine up
