I have a 96 force 120 that runs and starts well for the most part, but even when hot I have to set the throttle to 2/3 to get it to start then bring it back slowly or it will die. I also have the get on throttle quick at times and it will also die when coming off wot too quickly. I have run Sea foam in the gas and also deep creeped it several times but still have issues. I just ordered new plugs and hope to test it out this weekend. Is there anything else I should be looking at? It can get a bit hairy on the Missouri river when the boat takestrel a bit to get fired back up.
