Can you post pics of the #2 cylinder with the piston at BDC. I understand it is rusty which is an indication of water intrusion. With a broken head gasket, we can surmised it is due to the broken head gasket. But now with new gasket the compression is still quite low. Could it be the rings are already worn out or rusted also.
It all depends how much time and effort you want to spend on this to fix it but it is fixable unless the cylinder is seriously gouge. if it is just the rings or the piston, yup you can fix this for less than $200 or maybe $300 tops.
Search the forum on how to replace piston to give you an idea on how to do it.
