Hey everyone. So I have a 1989 force 125 and I was gonna change the lower unit oil (first time I've ever done this) and I think I have screwed up. There is a bolt/pin in the right side of the foot that I assumed was the drain. Well I took it out and it drained but when I went to put it back in there is some sort of metal bracket that has covered the hole internally and the pin/bolt won't go back in. After looking further I found the Allen head bolt on the very bottom that is probably the actual drain. How bad have I screwed up?? Help please!!!
