BackyardKrazy
- Sep 11, 2015
- 90
hey guys, I have been trying to trouble shoot this myself, but some of the procedure doesn't make sense. Ill start from the beginning.
the engine is a 1989 125hp. Works like a top, untill this morning. ripped across the lake, and when i stopped I noticed a skip and my idle was really low. Great what now. Anyways I got home, narrowed it down to the bottom cylinder, #4. i switched out a known good coil pack, and still the same issue. tried a new plug, same thing.
So i cracked open my manual and looked on outboard ignition.com. Its missing on one cylinder, so i tested my stator at 725 ohms between the yellow and blue (seems in spec) and between each trigger set i have exactly 50 ohms. Tested my compression, each cylinder hitting 140-150 no prob.
So it says to disconnect a kill wire from one pack, now I'm stuck. What do they mean? I will attach a pic of my wiring diagram.
Now one other thing. I have noticed its not charging like it should. The other day my volt gauge krept up to 14.2 after cruising wide open for 4-5 mins, but this morning stayed on 12V.
I thought maybe this would show up with the stator testing but it reads 725 ohms.
please help, Its my vacation this week and now im without a boat!!
