Bkok33
- May 3, 2016
- 72
So I saw the post about fuel and it seems like just stick with Regular fuel. Since that what the motors were designed to take. But what mix do you use. I have been doing 50/1. Which has been making a lot of smoke and has caused a set of spark plugs to foul up. Not sure if it's from the mix or the fact the motor sat for a while not running and changed the plugs out before running it. Also what do you think of running SeaFoam in your fuel?
