Chevyboi001
- Jul 8, 2015
- 29
have a 1989 force and i have fuel coming out the mouth of carb. which leads me to believe i have float or float sealing issues. my primer bulb will get hard but you can still pump it so not that hard (unless thats normal). any way im gonna pull the carbs apart problem is i have press in needle seats, and ive heard of lil tiny o-rings to seal fuel shut off. my carbs have no orings. i have a full brass seat then a seal on the tip of the needle. so does this mean i dont have the orings or are the orings supposed to be there??. i also have the foam looking floats, so im gonna try for new ones. but i wanted to address this needle seat question before i order parts. thanks
1989 force 125hp engine code 1251a9d
