Trying to understand why the rectifier just quit. 1986 Force 125 B model i had it running in the drive way on water muffs and ran fine. checked compression,new spark plugs,changed lower end fluid,greased all fittings. Installed the Blue Sea mini add a battery system, installed second battery checked many times by me and my brother all wired per installation instructions. Feeling good so go to the lake put boat in water, it will trun over, will not start. No spark, bring boat home and troubleshoot. The RECTIFIER is bad? any ideas on what happend? im not understanding, nothing i did should have made this happen. Help me understand. Thanks in advance.
