bluestreakj720
- May 9, 2016
- 13
1st off thanks for all the recommendations on prior issues on my rebuild. One of the last parts I need to find is the Exhaust gasket that goes between the "exhaust down tube" to the lower unit. Tried to order this from 4 different places and orders cancelled when they realized they don't have it.
Part number is ( Quicksilver OEM Part # 819066 )
Tried to order what I thought would work as far as gasket material from Canada even, but when arrived not so.
What do you guys/girls use to replace this gasket once it goes bad? My outboard is a 1992 Force 70HP and part is discontinued. Or should I even worry about it.
My concern is that it will be placing exhaust pressure on the lower crank seal if not replaced.
Any input is welcome.
