Skidad and nordin. I just wanted to update this posting and let you guys know the status of my issue.
I hope this may give you guys some knowledge for the future.
My high rpms in idle has been fixed.the issue was the float inthe bottom carb was set to high. Mean it was letting to much gas into the float bowl.
I noticed the bottom carb was leaking fuel like crazy. Leaking while motor was tilled down as in normal oporation and it was leaking.
So i figured, ahhh, i bet that could be where the high idle is coming from. The float isnt set properly and gas is continuously flowing into float bowl and flowing into carb and getting sucked into motor. So i took that carb off. readjusted to close valve.
Put carb back on and the top carb started to leak. So i did the samething to the top carb.
Now carbs dont leak one drop of gas.
Anyhow i took my boat for a test run and i ammazed.
It ran like a beauty.
No more high rpms when put into neutral.
However i did have to readjust idle stop screw becuz of the access fuel that was over flowing into carb was why motor raise high rpms.
So i unscrewed idle stop screw.
She idles at about 750rpms in gear and is idling at about 1000-1100 rpms in neutral.
Air mixture screws are at 11/4 turns out.
Skidad i remember you mentioned how your rpms raise abit for about 30 seconds then drops back down. Not saying that could be your issue but give it a try and see if your floats are set to high.
However it maybe be something else with yours sense your idle drops down 30 seconds afterwards. Mine never dropped back down.
Skidad and nordine i want to thank you guys for all the help and info and to help me on getting timing set.
Oh and by the way skidad i didnt even do the fuel diaphram rebuild. Problem was floats all this time.
Thanks again. Maybe one day will run into each other on the water. Lol.
