Hey guys,
I'm installing a new stator on an '89 85hp Force, and I'm not sure if it matters whether which green/yellow wires goes to the rectifier's positive/negative terminals. They're both green and yellow, so I'm assuming it doesn't matter if it's in the positive or negative terminal on the rectifier, but I just want to check with you guys. Any advice is greatly appreciated.
