I have a 90 hp Chrysler. Model 908h3a. When all the plugs are out the motor will turn over fine and the flywheel spins freely. If you put one plug in it will barely turn over. Same if all four are in. I've had the starter checked and tested under a load, checks fine. I have tested with several batteries even using jumper cables directly to the starter , same results. Plugs out fine , plugs in no go. The result is the same for a single plug in each individual cylinder. Even took the lower unit off , same results. Any help would be greatly appreciated.
