I put it in water this weekend and it dies when put into gear. I am assuming it is becauce of the back pressure. Gas tank has been drained and has new gas,new fuel water seperator. compression is 145 psi all 4 cylenders. idles good on muffs with a hose. I don't have a functioning tach so i don't know the persice rpm's. I could slam it into gear and it will run really well. I know I am supposed to forcefully shift into gear as opposed to easing it into gear but i think it should continue to idle/run in gear. Should I loosen up the lock nut and increase the the idling with the screw a little bit? Any help would be apericated.
