No Title
ok, I think I need to trouble shoot the ignition. I know there is directions on outboad ignition and other sites, but I dont know if I got the proper tools to do this, all I got is a cheap digital volt meter, test light and an in line spark tester. Ill include a pic of the dvm maybe someone can tell me if its compatible.
also Ill include that everything was fine until I took flywheel offf, I did do the lapping compound before re installing it, and when went to start it, no spark. I took flywheel back off to inspect wires and stuff, looked good but didn't get all the compound off flywheel, thier was some compound stuck between the magnets, hope this didn't short anything out. Also this is a 1987 force 50 with prestolite ignition. the coil paks were replaced by a dealer last year, he installed aftermarket cdi coils for the tune of about $700. Last year I had a no spark issue and couldn't figure it out so I took it in and thats what they said was wrong. I hate to take it back in if I can figure out this no spark issue myself, so any help would be greatly appreciated.
