Screamnreels
- Jun 25, 2015
- 14
Does this sound like the power pack is going out? Boat fires up runs great, run for,say, 20 minutes or so and cuts off. Will not fire back up but after and little time it will fire up but will not run when but in drive. Then after a little more time it will run like nothing is wrong until it cuts off again. I can go out side now and it will fire up, no problem. Had some say power pack may get hot then not have good contact until it cools. Compression good, plugs etc. Thanks again.
