Hi again guys. Been at least 18 months since my last query and I’m happy to report my Force has been going great here down under, probably done 30-40 odd hrs on it since my rebuild with the help of this forum.
During routine maintenance I changed out the impella about a month ago. It had been working fine up until then, after re assembly it seemed to pump water no worries. Turned the motor off and a couple days latter, prior to going out for a fish, fired it up and all off a sudden my tell tale didn’t show anything!!
Quickly turned the motor off, disassembled the pump housing, where I found nothing strange. Re assembled, fired back up, tell tale showed a stream again...
Went fishing, tell tale showed a stream all day.
1 month later, start boat, tell tale working, go fishing, tell tale worked all day until nearing my return and noticed its barely a trickle.
The 2 holes in the mid leg still show plenty of water and I haven’t over heated the motor, but for the life of me I can’t figure out why all off a sudden I’m having an intermittent tell tale stream!!
The tell tale comes from the plug at the top of the cylinder head, the impella was swapped out using OEM “quicksilver”.
I didn’t do any of the gaskets or housings, I’m wondering what to look for when I pull it all down again!!
It’s a 1992 90hp, has the stainless steel sleave inside the plastic housing, only thing I’m double taking is that someone at some stage over tightened the plastic water pump housing and it has a slight crack around one of the bolt holes. It’s not thru the plastic into the inside, plus it has the stainless steel insert right? Not to mention, its always been like this, but the tell tale has only just started playing up, maybe the crack has got worse.
Ill post pix upon disassembly
