Mo1
- Dec 11, 2015
- 76
Thank you Frank for the tip on removing the spline seal. I removed the spline seal and water pump and pressure tested the drive and shift seal and I heard and saw air leaking out of the drive shaft.
Just to clarify. Did you say I could remove the seals with a flat head screw driver. Ive seen videos were guys drill screws into the seal and remove them that way. Is that not necessary with this model?
I believe you said that I could remove the drive shaft? When I pull on the shaft it come out to a certain point and then stops. I don't want to force it for fear of breaking something and I don't want to remove it if I don't have too. Thank for the help.
Im taking videos so that I don't forget how to put this stuff back
