Mo1
- Dec 11, 2015
- 76
Hi Guys, New to the forum and this is my first boat. The boat started up but wasn't circulating water and the gear oil was milky. So I thought I would replace impeller and check seals. This model has like 4 different types of lower units and nor sure which one this is. I thought maybe the "c" in the model number meant it was the C type lower unit but the manual shows that one with 6 bolts holding the lower unit.
I removed the 4 bolts attaching the lower unit but cant find where to remove the shift linkage. Any help wold be appreciated
