Bought this motor a few weeks ago for $400. The old man told me it need new needle and gaskets. Did that, as well as new fuel pump gaskets. Not sure if the needle is sitting right, as it'll run for 5 min in the bucket then cut off. I'm assuming it's flooding, but not sure. Also, when I pump gas in from the tank, it'll start running out the front of the carb.
Any advice on the smoking and fuel coming out of the carb?
Any advice will help as i'm clueless.
Attached links are videos of it smoking.
Also- I'm so confused as to who made my motor. It says "force by mercury marine" but also says "gamefisher" on the back of the housing. So confused by that too.
