My 85 hp Force won't start. Spins over but won't bust off. Let me go over what has been done and checked.
1. Blue spark on all cylinders.
2. Fuel pump good, no tears and is pumping fuel. Fuel system is clean, new water separator filter, and lines.
3. Carbs been gone through twice, I'm confident they are working. Not my first rodeo.
4. Reeds checked and replaced.
5. Head gasket replaced.
6. Compression test, 115 on no.1, 115, no 2, 113 no.3 and compression holds on all three.
And, timing is dead nuts on it, checked yesterday.
7. No fuel is reaching the plugs, after an attempt to crank, plugs will be dry no fuel is reaching them.
8. Can spray ether straight into carbs, nothing, maybe a slight backfire on occasion.
9. I think it's sucking air from somewhere. Could the base gasket cause this issue? Or, is the problem rings, or seals?
Love the I boats forum, you guys are knowledgeable, and timely. Any opinions are greatly appreciated. I hate just running on my trolling motor. Need to get fixed asap.
Thanks,
Striper20
Thanks,
Striper20
