fisheymikey
- Jul 30, 2012
- 450
your stator generates the first wave of energy then the CDI amplifies and sends the energy to the coils. trigger just tels the cdi went to send it. coils aplifies voltage again then the spark plug ignites the fuel and air.
problem with the cdi there is NO way to test. ppl here will tell you take a cdi that works... here is the problem you will never now how it works because sometimes these cdi work or dont work. all components on these engines they have resistance and voltage specs and can be easilly confirmed. the cdi is tied directly to all ignition components. this is only my advice but i have learned the hard way. its up to you to diagnose.
