Muddydec
- Aug 16, 2007
- 14
Hello its been a while since last issue with the 125 force motor. Here's the skinny, went out last month motor ran fine for half the day then all of the sudden bogged down and died. made it back home scratched my head a little and thought might have been bad gas or fuel issue. Drained the fuel and was taking the bowls off the carbs and noticed the plastic outer plastic piece that connects the trigger to the tower was broke. So ordered the part installed it and set the timing according to the manual it said 34 static. the thing is still hard to start, rough idle and will not go WOT. Not sure what my next move should be. Is the manual wrong with the timing. I keep seeing a lot of different degrees on the threads. 28 30 32 34. What is correct? When the plastic piece broke did it screw something else up? Need help!! Missing great fishing!
