psemerzaki
- Sep 2, 2015
- 2
great site guys, ive learned a lot before signing up hopefully more to come.:joyous:
So i have an 88 bayliner capri with a force 125 outboard (sigh). The issues im having are as follows:
Overheat-only at 1/2 speed to WOT or 15mph and above. The buzzer will shut off after 30 seconds of idling. Always good water out of tell tale, but the motor is definitely too hot. I have replaced T-stat, Impeller and housing, gaskets etc, head gasket, flushed the system with garden hose. Still get overheat at 1/2 to WOT. I have read the prop can have an impact on this, which my prop is way wrong for the engine, also ive heard of this problem being due to water passages PARTIALLY clogged hence only at 15mph and above. Been dealing with this all year BTW.
Also broke the motor mount this past weekend, and the trim has never worked. The electrical for the trim is fine it checks good. I can get a good used motor mount/trim tilt assembly for $550. On top of this I need a prop so add another $150.
Is this thing worth the hassle? Or should I cut my losses and start with something nicer? Any help on the overheat would be great also.
Thanks in Advance guys. Sincerely, sad boater.:grumpy:
