Hello, New to the posting but long time lurker. First off thanx for all the write ups they have helped me in the past greatly. I purchased a new boat and it has a force 150 on it, While out on her maiden voyage we had lots of "carb issues" hesitation, bogging, stalling, etc. Really only wants to be just off idle or wide open. The main issue is that it is dumping raw fuel from the prop exhaust. I noticed this when i was washing it down and saw it pouring out! then calculated and found we went through 40 gallons of gas in 4hrs of trolling! yikes. I have since checked spark and compression, all really good, cleaned the carbs which were nice and clean. I now have the top two carbs off and the reeds out, only on one reed pedal you can see minor daylight through would that be much of a problem or is it somewhere else? Thanx in advance for any help out there.
