I am not sure I understand. Is the engine slowing to about 3/4 throttle with no fuel problem? Or, is it running out of fuel at full throttle? If it is running out of fuel, it will almost stall. If there is no fuel problem, the control handle is backing off. Most do not have a tension adjustment and you need to keep your hand on the handle.at full throttle.
