Themanofsteel
- Jul 11, 2015
- 312
I have a 1988 Force Outboard 85hp. It recently seemed to bog down or loose power at full throttle so I replaced the fuel pump diaphragm and gasket. Now it seems to intermittently stutter or shake in neutral or throttle. I attached a picture showing the diaphragm. You can see it can't really be put on backward or anything. Did I do something wrong? Here is a Dropbox link to hear what it does. https://www.dropbox.com/s/c3guj06jbg..._2255.m4v?dl=0
