I have a 1989 35hp force outboard ! ran hot 1 day took home removed lower unit installed now water pump impeller.Took boat out still got hot replaced all fuel lines and disconnects thought possible vacuum leak making engine run lean but no luck?Now put on tell tail line , now have motor in barrel of water when motor cold water flows good from TT line as motor gets hotter water turns to steam! did compression test top cyl 120psi bottom cyl 122psi . anybody out there have any ideas why it gets hot?
