Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Installing cable on steering drum
This topic is closed.
  • Installing cable on steering drum
    From tashasdaddy
    ______________________________________________
    installing cable on steering drum
    thread tiller line thru small pass thru hoe inside drum. Pull line thru until equal lengths extend from the ends. Thread one end of line thru contoured hole in upper flanged end of drum, and opposite end of line thru rectangular hole in lower end of drum.
    Wind each line 4 times around in opposite directions, by following the groves in the drum. Both lines should lead off the top of the drum at it's center, so that as the steering wheel is turned one line wind up and the other line unwinds. Apply common adhesive tape over the assembled line to hold in place temporarily if desired.
    "JUST KEEP ON, KEEPING ON"©
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    Re: Installing cable on steering drum
    It's a little more tricky if both cables run down one side of the boat. I always end up about an inch to short on one end or the other.
    The fishin' is always good. Sometimes the catchin' is better.
    • #3
      Ok... that part I have no problem.. The problem I am having is findnig a replacement drum for a 50's model fiberglass boat... manual steering with ye ole clothesline hook up... I have scoured the net and cannot find a 3/4 inch hub replacement drum... if anyone can help... please do!
      • #4
        Hi Wooz
        How are you doing in your search for the steering parts ? I have a salvaged setup , I'll check the dimensions if you still in need . I'm on the MFG boat section as pduquette if you need to look me up .
        Peter
        • #5
          I bought an old (my first) boat out of an overgrown field, so replacing the cable was one of the many jobs that I did on a learn-as-you-go basis.
          I found the attached pic, and it really saved my bacon. (I'm visual)
          Hopefully it helps someone else..
          60...something..Arkansas Traveler, 35hp Merc
          • #6
            you will need about 50 feet of coated cable, lowes sells it. find center. now thread the drum as above. hold cable to drum with duct tape. take the wire off the bottom of the drum, thead it thru pulleys, (Purple) to the port side of the transom. now take the wire of the top of the drum, thead it thur the pulleys (Green)to the starboard side. DO NOT CROSS THE CABLES, this causes binding.
            set the steer wheel to center. now take the wires from each side, run thru pulley on motor bracket (Brown) and back to their sides, should be a spring (samll blue) on each side with a loop or pulley. run the cable the the loop or pulley, bring dead end out tighten the cable putting tension on the spring. and clamp the cables together. you have to have a good bit of tension, as the tension is what keeps the system together.
            FLORIDA GATORS
            TEBOW Country
            Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
            That is what these forums are for. Post your questions, in the appropriate Forum.
            • #7
              FLORIDA GATORS
              TEBOW Country
              • #8
                one more:
                FLORIDA GATORS
                TEBOW Country
                • #9
                  here's more info. http://forums.iboats.com/showthread....ulley+steering
                  FLORIDA GATORS
                  TEBOW Country
