Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Volvo Penta AD41B water pump
This topic is closed.
  • Volvo Penta AD41B water pump
    Trailer mounted 26 foot flybridge boat. Work done high and dry.
    I usually replace the raw water engine mounted water pump impeller every few years. This time when I pulled the old impeller, one vane was missing. Not sure where it went. Not anywhere that I can see. Connected to the pump, directly above it, is a screen / filter. No vane, or pieces caught there. Is it possible for the vane to get stuck somewhere in the cooling system ? Do I have to find and remove the piece? Do you think it got ground into small bits and pieces and passed through the system ?
    Hoping someone with more experience can answer this question. I am hesitant to run the engine without knowning the risk.
    YOUR COMMENTS PLEASE !
    Thanks
    The raw water filter is after the raw water pump so chances that impeller parts big enough to cause a blockage to slip by are small. Most likely the lost vane fell down in the intake hose where it still sits.
    • #3
      He probably found the chunk in the 1 1/2 years since posting.
      Closed.
      BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
