Hi all.
Have a single KAD300 hooked to a DP-G drive in a 2005 planning hull cruiser.
Engine is just reached to 609 hours, clean bottom, drive, props, impeller changed last year and did 95 hours, heat exchanger, oil cooler, power steering cooler and aftercooler cleaned 3 years/280 hours ago also turbo and compressor.
Last summer while cruising on a cross/beam sea on plane jumped over a wave and suddenly overtemp alarm went off, also the overtemp indicator flashed on the alarm panel, temp gauge showed 100C. Immediately pulled back the throttle to neutral and temp decreased to 85C then hit the throttle but engine revs limited to 2200.
Stopped and restarted and engine ran without over temp. 15 days later from this incident same happened again since I jumped over a beam sea wave. Checked the impeller and it was fine. Also I'm a year round boater and have never had an issue like this until one month ago.
I run on plane at 3000rpm reaching 18,5-19 knots, trim tabs fully retracted and drive trim -2 to +2 according to sea and load conditions.
One month ago while on plane cruising around an island where I spend my summers, turned to port 30 degrees via autopilot and overtemp alarm went off BUT temp gauge was at 85C (which is the degree of 1st thermostat and at 92C 2nd thermostat opens) pulled back the throttle jumped in to the bilge and checked the seawater components/hoses buy IR temp gun and there is no real overheating also outdrive was intaking and discharging water and impeller housing was cold.. Hit the throttle and couldn't pass 2200rpm. Stopped and restarted then no problem.
This fake overtemp problem arised last five consecutive days where I was on the boat, alarm wents off after a few minutes of getting on plane on a wavy day, and once happened at the marina entrance to pass the other boats I hit to 3500rpm and then happened while I was cruising 20 minutes problem free. Yesterday I uninstalled the impeller and it was spotless and installed it back.
Talked to my mech and he thinks this is not a mechanical issue and would be electrical and heâll be onboard at the weekend to hook a vodia . Iâm guessing that while jumped over the waves the temp sensor in the exhaust elbow loosen or moved a bit or broke etc and cause false alarm then pretends the engine as there is real overtemp.
Forgot to mention that EDC control panel D button gives 1.1 code which means there is no problem, but I wonder if really an overtemp occurs will it show a trouble code or if Iâm having an electrical problem shouldnât it blink different from 1.1?
Hope someone can shed some light to my problem.
Thanks in advance.
Thanks in advance.
