Scarborough
- Sep 25, 2011
- 42
Hi,
Had this boat for a year now. Bought it in Sydney tested it and it run beautiful, lots of power. Trucked it up to Brisbane and noticed that port engine did not have the same power. Still managed to get to 3500 revs but only after I had the starboard engine at 3700 then pulled it back to 3500. This was ok and I managed to get by but then it got worse and I could only get to 3000 revs. I noticed the water separator filter had black fungus. By recommendations I bought fuel doctor additive and shocked treated the tank (1 common tank for both engines). Seems like the fungus is gone but still revs at max 3000. Note that bottom is clean and props are new as I got recommended to re prop by a local marine "engineer".
Checks done to date.
- engines serviced
- legs serviced
- turbos both spin freely and as far as I can see looks ok.
- back flushed both fuel lines from engine intake back to tank (saw another post suggesting it might be nets on the pickup pipes that were clogged)
There is no black or white smoke at all except for some white smoke on startup for a very brief time. Worth mentioning is that when sitting on the plane at 3000 I can pull back the throttles to half BEFORE any reduction in power?? Both engines revs to above 4000 in neutral, I know that doesn't mean anything but I have also been told by a marine "engineer" they are in good condition.
Thoughts,
I am thinking fuel issue, after trucking up to Brisbane some marine growth got lose and got partially jammed somewhere to the port engine. The two pickup lines are on the tanks bottom port side. After the shock treatment the fungus is gone but maybe the residue of an old tank from 1985 is still clogging the lines? The other issue could be turbos dead but from what I am reading the would show as getting black or white smoke and I can still hear the turbos kick in at 2500. It just feels like the throttles only gives me half the power, could it be the smoke limiter membrane broken or not adjusted correctly? These engines were installed in 1997 and have only done 580hours and still have the Volvo seal on the pumps.
At this stage I am at a loss and using the boat for offshore fishing with my son is out of the question until resolved. Please let me if you you might know what it causing it or test I can do check things.
Cheers
Mr frustrated....
- engines serviced
- legs serviced
Thoughts,
Cheers
Mr frustrated....
