I have a sessa oyster 35 2001 with 2x Kad 43 engines with DP outdrives.
Does anyone now if the engine has to come out to replace the gimble bearing or Universal Joint.
My Boat was working beautifully when after a right turn a loud grumble came from the port engine area. There is a small grumble noise when driving the boat in a straight line but on a turn the noise is terible. A local mechanic has advised that its the universal joint or gimble bearing but he cant be sure but with either the engine has to come out of the boat.A sessa dealer has advised that this may not be the case but I wanted another opinion if possible as the labour charge could be only a few few hundred or a few thousand.Many Thanks anyone who can help.
