Starboard DP-E will not operate. Electric hydraulic motor does not have electric power. I found the RED wire to the Relay disconnected, the spade terminal dissolved by corrosion. I cleaned the Housing, replaced the spade terminal. When I pressed the control panel switch at the helm, the switch burned through. Ugh!
1. I have replaced the Control Panel Switch, left one wire unconnected as before. The indicator lights come on, rotate.
2. The fuse mounted on the engine near the fuel filter is a reset type (not original. ) I read 12V across both terminals.
3. I replaced the Relay near the hydraulic pump with a new spare: No change, no electric power, no help.
4. Port side DP-E power tilt functions normally, no problem there.
I cannot see a fuse near the electric hydraulic pump motor. Anyone know if the DP-E model has a fuse elsewhere? MY ENGINE SERIAL IS; 2204157180; MODEL AD41P-A.
I note Don S. discussion of July 2, 2011, and the posted wiring diagram. My DP-E Relays do not seem to be the same as the Relays in the diagram that is there are not separate relays for "Up and Down". However, the relay connection are the same, 30 through 87a, so is the color coding.
This is driving me nuts. Any suggestions to remedy this, or knowledge about any available tech super qualified to trouble shoot this condition located around Anacortes, Washington? Thank you for any thoughts, suggestions.
pv
pv
