Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Need to bleed air from diesel
  • Need to bleed air from diesel
    I need to bleed the air out of the engines on by 3870. Can anyone give me the proper procedure for doing this? Do I crack the lines going to the injectors and pump until I see fuel coming out or do I crack the return lines on the top of the injectors?
    If you have return lines, you should not need to bleed. Normally high pressure common rail motors have return lines and you never bleed those simply because the pressure will cut thru your hand
    You should only need to fill the fuel fllter with fluid
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
    • #3
      Ayuh,..... Welcome Aboard,..... 3870, by whom,..??
      Is this a mechanical, or electronic injection diesel,..??
      • #4
        Hi
        The return line should be LP, but no need to touch these.
        If you have a manual priming pump on the engine, crack open the filter bleed screws just before mech pump then pump the priming pump by hand until fuel comes out with no bubbles or spuradic squirts. Then try firing her up.
        Failing this, crack open the injector compression fittings at each cylinder and with someone at the helm and someone else at the engine with spanner in hand...crank her over. She should fire up eventually, all be it roughly. Close and tighten (not too hard) each cylinder as a clear spurt of fuel is seen at each one.
        If you have pre filters (water separating), keep these closed when hand priming.
        It can all be a pain in the arse, but is usually caused by changing the filters incorrectly or running out of fuel.
        Note: if going as far as cracking open the injector compression fittings, do not loosen all the way. Only just enough so you can just move the fitting up and down by a mm or so. Leave plenty of threads on. These are HP and will do you damage....best case, atomised fuel in the face and eye...worst case missing finger and or hydraulic injection. Not good.
