Volvo Penta Cooling
Hi Guys
Can anyone tell me whether you can change out the small diameter RW pump from an AQD40A to the larger diameter like is on the AQAD41's and similar?
Grub54891
Why do you want to change it? Factory set up is usually just fine, if you are having problems a bigger pump will hide the real problem.
