Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Fuel Line Hose - Volvo TAMD41B Diesel
  • Fuel Line Hose - Volvo TAMD41B Diesel
    The yard replaced the lines to and from the fuel tanks on my Volvo TAMD41B diesel inboard engines. Three months later, they're leaking.
    If you have this engine with original hoses, can you tell me what the hose diameter is?
    The yard used 3/8" - 9.5mm hoses. The barbs are 9mm and the hose goes off and on easily unless clamped.
    Should the clamps be over the narrow part of the fitting (to hold the hose on) or the barbs? Or try to fit two clamps on?
    Thanks for any help.
    Click image for larger version
    I would suggest using 5/16 (8mm) fuel line. It should be able to be pushed over the 9mm barbed fitting. Get a short piece and give it a try
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 SeaDoo GTX
    Raw Water Pump Maintenance
    Merc Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
