Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
D4 / dph trim sensor position
This topic is closed.
  • D4 / dph trim sensor position
    My trim sensor indicator is changing numbers when I start the engine after being shut down. So I calibrate the evc so as the range goes from -3 to 45. I operate at 3 or at + 6 from being bottomed out. The first time I use it after calibration everything is correct. The following day when I start it 3 will now be 5 but the leg will not have moved. It is still 6 from bottoming out. And it slowly sneaks up until I do a recalibration.
    Does this sound like I need a new trim sensor? I hit a deadhead a year ago and the cylinder on the side that the trim sensor is on had to be replaced. The repair shop did a very poor repair job on the other pieces so I am wondering if they did something to this as well. Eg. The rear propellor was mounted backwards, the tilt cylinder hose was not tightened, the steering system was not bled.
    Hi, I saw your post on Iboats forum regarding trim position frm september last year. I have the exact same problem. How did you solve it? BRG Niklas
    • #3
      nickenl
      Please read the Help Tip on top of the page and start a new thread. Roger has not visited since starting this thread last year.
      Closed.
      BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
