sogood
- May 11, 2016
- 361
I've been trying to adjust my gear shift cables, as I had reverse gear with no problem, but no forward. I can engage forward by pushing manually on the cable. Everything moves as it should, remote cable and shift cable. I followed a vey good tutorial on youtube but found that when marking and measuring the remote shift cable, I only had 2 1/2" on the sleeve as opposed to the suggested/recommended 3", give or take 1/8". Where have I lost my 1/2"? Is there adjustment possible at the shift lever?
There is no way to adjust the distance at the motor end of the cable. My shift mechanism is a single lever Quicksilver, with the throttle only button in the base.
Any thoughts appreciated.
