Unit shifts to reverse fine, forward their is either a lag before engaging or after use, it doesn't engage until high RPM, then jumps into gear. I replaced the shift cable and tried adjusting the stern drive end to several positions but get the same result. The lever moves to all three positions freely when not attached to cable and the props lock in when shifted to revers and forward. Any ideas?
Thanks much as I am out of them.
