I bought a 1996 sea ray recently with cracked block, swapped out the engine for a reman, finished everything up, took out to the lake and I hear a grinding noise in the outdrive when turning at around 2,000 rpms. Filled the outdrive with oil till it started coming out of the upper hole.
What gives? Bad engine alignment? Not enough oil?
Thanks everyone!
Thanks everyone!
