Please help!? Shift cable/throttle cable?
Donnyb83
Thank you AJ appreciate it. As much info as I can get from anyone and everyone that knows about boats is awesome. GA boater just took some pics. Bout to post. I followed the thick cable. It had me confused because it was snuck around the wiring harness which is about the same thickness going into the throttle. When I looked under n followed with my hand I untucked it and yep goes right to steering. Def want/need and going to replace that one as well.
Donnyb83
I'll def need to order all of these things. Steering cable and throttle/shift cables. And all the walkthroughs as possible lol.
ajgraz
Yeah that steering cable looks pretty messed up. I am not familiar with that style, looks like it anchors at the wall of the splashwell? Every Merc steering cable I've ever seen anchors at a steering tube on the starboard side of the motor, extends through to the port side, then links back to the motor...but again, with such a narrow splashwell the style you have might be the only thing you can use. Does the steering cable have any manufacturer or part # info printed or stamped on it anywhere? Maybe someone else has seen this type before?
Donnyb83
I'm going to look to see if I can find anything on the casing right now that u mentioned it.
GA_Boater
For the steering cable you need to stick your head under the dash and see what brand of helm is behind the dash. It's either a long rack and pinion or a round rotary system. Actually for a few bucks than a steering cable, you can get a complete new system which will be good for years, then you don't need to match new cables to the helm. I may have given this link in an earlier post - http://www.iboats.com/Boat-Steering-Systems/dm/view_id.217122 You can see the difference between the two helm types.
Your steering cable uses one of these splashwell mounting kits through the side of the splashwell.
Basically it is a side mounted tilt tube and it is adjustable for steering side to side movement. I think the boat maker used it because it doesn't use the motor tilt tube and link arm which can cause clearance problems with a narrow splashwell.
Donnyb83
So this is rotary I believe from looking at the link you sent. From the pics they look smaller. Are they all about this size? I also seen one that said quick link or something like that. Can I use that one?
Donnyb83
Thank you very much, GA boater. I'll be ordering this week for sure! Possibly today
Donnyb83
I'm sorry guys another question. I measured as best as I could the throttle/shift cable while still hooked up. Comes to 13 ft roughly, to the end of the throttle. Did I measure that right? I also measured the steering cable,only the cable though. (Not the threaded part) and got about 14 feet. Did I measure that right? Also if the cable I get is a little longer, can I loop it? I figure it can't be an extra 2 ft that would be too long I'm sure. I could be wrong though. Lol.
Donnyb83
Ok I bought my new steering, shift throttle cables. Going to try to replace it tomorrow. Can someone help me out? I didn't buy from iboats cause I found mom and pop marine shop near me and they were only a couple bucks higher in price. Can someone post some links to guide me please. If not I guess I'll use a YouTube video closest to my setup.
