I replaced my control cables, shift and warm up, and I am having a bit of trouble adjusting the warm up cable. Also, When the lever is all the way up, it won't crank.. If I lower it about 1/2" it starts. Also, I have an original service manual and I followed the adjustment procedure in the manual, but the problem is that mine doesn't seem to "act" like the manual says that it should. When I put it in reverse until there is some shifter movement, I adjust the cable until the hole is slightly aft of the pin, then I put it into forward, untl the shifter moves a bit, the hole in the cable is supposed to be just forward of the pin, but it is way off. What am I missing? Thanks in advance guys...Mark
