have had the boat a while, when I put it in the water started it, backed up, shifted to neutral then it would not shift to drive or reverse,i looked on this site and someone had a similar problem with a 1993 Johnson 60hp, but the post has been removed so I was wondering if some one could help,me, it is a omc 1994 concealed control box on a 1994 gruman boat with a Johnson 40hp. I just took the whole unit apart,thinking I might see something broke but so far it looks ok, one thing though,when I took the neutral safty swtch off it had I wire off the connection,but I don't know if this makes a diff or not
