ajgraz
- Mar 1, 2010
- 1,858
Working on cleaning up the rigging on my 17' center console. I've always been told that the control cables should loop at the motor end, for freest movement. But, on this new-to-me center console (and on any CC I've seen) they do NOT loop, they use the most direct connection possible.
On my boat, this means that when the wheel is all the way left, I get a spot with a bend radius of about 10.5 to 11 inches. Thing is, the motor well is kind of narrow on this hull; and after measuring A LOT, it seems to me that if I did loop, then it'd still have to have something like a 10-11" bend radius with the wheel turned all the way to the right. Cables on it now are your typical 16" bend radius specification, and I do believe they are binding some.
SO, is it standard practice to NOT loop on a center console? Every other boat I've had before had plenty of splashwell to contain the loop. And I could see how having a loop on the deck of a CC would be a major trip / foot-trapping hazard.
Any reason I'm overlooking that I SHOULD loop?
I know there are upgrade control cables that specify bend radius as little as 8", I am thinking about going with those, whether in the current length or long enough to loop.
