Twin Merc 4.3LX 1989 s/n OC534197 & Alpha One MR S/N OF162055
Only one engine as the P/S hook up.
Problem :Hard to turn steering, seems to have Air Bubble stuck in the system, I can not get ride off. When I turn the steering weel right & left very fast
it seems to function OK. I can feel the steering weel freely moving.
I went throught the steps of removing air bubbles with out success.
The power steering reservoir is filled up of oil as per the specs. The Belt is OK. I even switch both P/S Pumps (from 1 engine to the other) thinking the pump
could be defective. No change there also.
I replaced the Power Steering Cylindar Ram, no change there also.
I've read, I think, there is a P/S Cooler somewere on my engine that could be the problem.
Were is it located?
And what is the function of this Oil Cooler in relation with my Power Steering?
I appreciate your help please.
Thank you
Were is it located?
Thank you
