Need longer cables
Roca
I need longer throttle and shift cables for a johnson 70el77s on a 1962 starcraft. I'm fairly new to boats, but know how to work on motors. I need to know what specifics to look for. I'll measure in the morning to know what length I need. Thank you.
gm280
Roca, what remote control unit do you have. Could it be the older OMC two handle setup that takes the series 400 cables? Without pictures it is just a guess. If you do use the 400 series control cables or any type cable for that matter, make sure you leave enough length so then the engine it turned the furthest angle there's still enough cable length to support that turn. Post some pictures if you need more specific help. JMHO!
