kamikazz1234
- Aug 18, 2015
- 2
My Shift cable broke on my 2005 Mercury 115 two stroke outboard motor. I replaced it and adjust the cable to fit easily on with the motor and shifter both in neutral. But the motor would only go into F and would not go into R. So i adjusted it and then it would only go into R and not into F. I tried several different adjustments, but no luck. I even adjusted one time and it barley went into F and R (but it made a bunch of grinding noise). I unhooked the cable and moved it from F to N to R by hand and it shifted through all 3 setting just fine.
Two Questions............could I have bought the wrong replacement cable (too short of movement) or is there an adjust up at the shift handle to make the range better to reach both F and R?
Thanks in advance for any help you can give.
