sdexcalibur
- Apr 27, 2008
- 38
Ok, I buy a radio from Walmart (going to be an easy install ), it comes in the mail, I take it out and still like no big deal. I attach the 2 wiring harnesses to the radio and it looks like I really only have to worry about one wire. Yellow (constant power) so I grab a wire splice it to the yellow and start touching it to my electrical fuse box....nothing. Then I read you have to have the red (switch) and yellow wire hooked up. Some people suggesting (web search) to tie the red and yellow together. So I do that and proceed to touch where I think should be power. Under the sterring wheel I have the main electrician hook up. It's old school fuses (glass), all the gauges and switches go into it. Just to the top of the board their is a push tab fitting. So I figure that is the power. Also have 2 copper strips off to the side that have 2 or 3 wires attached I figure those come from the battery. I touched the exposed wire to almost everything under their with the hopes it would power up and then I can just attach it to that, but it doesn't power up. Any help would be great. I shouldn't need the ground attached for it to turn on should I?
